Vous le connaissez lui qui a deja 125 000 km avec son AT de fev 2016? interessant de voir l'entretien et problemes rencontrés:
I still stand by my opinion and the AT is my favourite bike to do a round the world trip, but Honda definitely has to improve their world wide customer service!
May 19, 2018 Change of tires (Mitas E07 front normal, rear Dakar version) and rear brake pads
124719 km 2 h 256 €
Mar 18, 2018 Oil change (15W 50 Motul) and cleaning of air filters
116480 km 3 h 50 €
Feb 13, 2018 Change of only the chain
109565 km 1 h 100 €
Jan 21, 2018 Cleaning of air filters
105560 km 3 h 0 €
Jan 19, 2018 Change of tires (again Heidenau K60 Scout)
105321 km 3 h 216 €
Jan 10, 2018 Oil change (10W 40 Liqui Moly) with filter, replaced right mirror, fitted additional windscreen support mount, change of all brake pads
103301 km 8 h 200 €
Dec 14, 2017 My first flat tire (rear)
101756 km 3 h 0 €
Dec 06, 2017 100.000 kilometers! (62137 miles)
100000 km
Nov 28, 2017 Change of rear brake pads (custom made)
98455 km 2 h 7 €
Oct 27, 2017 Change of tires (again Heidenau K60 Scout)
91779 km 1 h 200 €
Oct 20, 2017 The frame to the windshield and navigation mount welded again (different spot this time)
90615 km 6 h 15 €
Oct 12, 2017 Oil change (10W 40 Motul)
90467 km 1 h 40 €
Oct 11, 2017 Change of the rear brake pads 90457 km 1 h 78 €
Sep 15, 2017 Cleaning of air filters 86951 km 2 h 0 €
Aug 07, 2017 Change of Oil (10W50 Castrol), change of tires (again Heidenau K60 Scout) and new DID chain and sprockets 77250 km 5 h 450 €
Jun 23, 2017 Oil change (10W40 Honda) 68428 km 1 h 35 €
May 03, 2017 Oil change with filter (10W40 Mobil1) and tire change again to Heidenau K60 Scouts 60983 km 4 h 500 €
Apr 27, 2017 New progressive Wilbers springs fitted in the forks, together with new fork oil of course 59626 km 2 h 250 €
Apr 22, 2017 Change of the front brake rotors together with new brake pads (all OEM) 59143 km 1 h 350 €
Apr 07, 2017 Change of the OEM suspension strut to a Wilbers suspension strut 57132 km 1 h 850 €
Mar 15, 2017 Change of oil (10W40 Motul) 50292 km 1 h 40 €
Mar 07, 2017 Big inspection: new spark plugs, valves adjusted, coolant and brake fluid changed. Additional: windshield and navi mount welded again, one top spark plug socket exchanged, top case mount improved, new Barkbusters hand guards, new clutch lever and new food pegs mounted 49625 km 20 h
Feb 18, 2017 Rear brake pads changed 47153 km 1 h 28 €
Jan 18, 2017 Change of air filters to reusable ones from UniFilter and fitting of the side stand base extension (both from Touratech) 43630 km 1 h 170 €
Dec 07, 2016 Change of oil with oil filter (5W40 Liqui Moly) 39780 km 1 h 50 €
Dec 06, 2016 Change of tires (again to Heidenau K60 Scout) 39715 km 1 h 190 €
Nov 15, 2016 New DID chain and sprockets mounted. 38350 km 2 h 210 €
Oct 02, 2016 Front brake pads and Oil changed (10W40 PPT) 33535 km 1 h 76 €
Sep 16, 2016 Rear brake pads changed 31176 km 1 h 30 €
Jul 18, 2016 Both rear bearings changed. Sadly we couldn't get new sealing rings. 19105 km 1 h 25 €
Jul 17, 2016 warning Right rear bearing broken and very rusty. 19105 km
Jul 14, 2016 Change of tires (again to Heidenau K60 Scout), change of air filters, change of oil with oil filter (5W40 Liqui Moly), new fork oil sealings, change of fork oil (10W Liqui Moly) and fitting of neopren protectors 19044 km 10 h 350 €
May 31, 2016 warning Fork oil seal ring on both sides is leaking 11570 km
May 31, 2016 Set Button works again! Incredible what 42 degrees can achieve
10987 km
May 27, 2016 Broken welding seam of navigation and windshield holding welded. Additional fixation with cable straps. 10066 km 2 h 0 €
May 23, 2016 warning Right side of the bracket broke, where the windscreen and the GPS is mounted. Probably because of the weight of the GPS and heavy vibrations. 9546 km
May 20, 2016 Chain tighten and Oil change: the touratech motor protection has to be dismantled entirely in order to reach the second oil screw 9047 km 2 h 50 €
May 19, 2016 Test of the spare switch unit: only after 24 hours the set button was already going badly and got stuck for a short time. That is why I decided to skip the change and threw it away. 8750 km 24 h 0 €
May 07, 2016 Changed tires to Heidenau K60 Scout 7145 km 1 h 25 €
Apr 20, 2016 warning Set switch gets stuck again. The problem does not go away. But I haven't used the spare yet, because it is a lot of work to change it and I am afraid that the new one will have the same problem. While standing without gloves and with two hands I can still use it, that's enough for now. 2000 km
Apr 05, 2016 Set switch is working again. It seems that the problem occurs when it gets wet. Still I got a new spare to take with me. 1200 km 0 h 0 €
Mar 17, 2016 Inspection at 1000 km 1047 km 1 h
Mar 11, 2016 The SET button of the left switch unit stays pressed in and doesn't get out anymore. 532 km
Feb 17, 2016 Vehicle licensing 0 km 1 h 60 €
Feb 11, 2016 Assembly of a main stand and steel pipes for the brakes 0 km 5 h 500 €
